Farmall Tractors Discussion Board
Re: A's Brake Pedal Lube?
Posted by big fred again on May 26, 1999 at 20:07:43 from (199.238.169.114):
In Reply to: A's Brake Pedal Lube? posted by Lynn Hait on May 26, 1999 at 06:08:10:
Lynn,
Okay, I see what you mean now. I just took the sheetmetal cover off the clutch/brake shaft area and it occurred to me that you probably don't have that sheetmetal guard. The threaded holes you are seeing are the holes for mounting the guard. Should be three holes. Definitely no grease fittings. Sorry. Still sounds like you get to make a trip to a salvage yard.
Post a Followup
: Re: Re: A's Brake Pedal Lube?
