Farmall Tractors Discussion Board
Re: A's Brake Pedal Lube?
Posted by Daniel on May 27, 1999 at 07:25:41 from (206.74.50.21):
In Reply to: A's Brake Pedal Lube? posted by Lynn Hait on May 26, 1999 at 06:08:10:
My super A has grease fittings on the cast supports that hold the break pedal rod. They are on the bottom away from the holes that hold the cover over the pedals. My right break rod was worn out, too. IH still has the rachet paw/rod for ONLY $185.00. I had a machine shop cut off the old rod and turn a new one to weld in its place. They also bored out the casting and put in a bronze oillite bushing. I figured anything from a junk yard would be worn out too. Good luck.
Post a Followup
: Re: Re: A's Brake Pedal Lube?
