Posted by Bob O2 Martin on March 22, 2009 at 06:19:15 from (71.7.54.219):
I'm gotten into my parking lock on this thing and found out it wasn't stripped like I had originally thought. The mounting bolts for pin that drives the pawl down were loose. I tightened them down and the the lock holds now.
But if I could pick you guys' brain one more time I would really appreciate the help.
I only have the spring on the outside, but there is an adjustment (center nut that drive the "L" type end linkages). That can be set to put some pressure on the lock with a kind of a "snap over" point when you apply the parking lock.
The question is do I want to set any pressure with that adjustment or should the only pressure on the pawl be the out side spring?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
