Farmall Tractors Discussion Board
Re: MD Vibration
Posted by Harvey on May 28, 1999 at 08:27:31 from (152.163.207.189):
In Reply to: MD Vibration posted by Ike on May 28, 1999 at 06:25:53:
Ike: At high RPM and NO load..?? Maybe not engine but maybe clutch..? Try pushing in clutch when that happens to try and eliminate that possible source.. How about a worn fan that needs rework. A large fan under high RPM can shake if worn out.. Try different things befor tearning into the engine but half gallon of oil per day is way too much even for an old MD.. Very expensive engine to overhaul.. gd luck harvey
Post a Followup
: Re: Re: MD Vibration
