Farmall Tractors Discussion Board
Re: M won't stay one constant RPM at idle
Posted by JK MN on May 28, 1999 at 11:34:14 from (207.242.199.131):
In Reply to: M won't stay one constant RPM at idle posted by JustinB on May 27, 1999 at 22:32:25:
JustinB, In addition to the other posts, check the tightness of the butterfly on the throttle shaft. It is attached with two screws that should be tight. (This will require removing the complete carb). Also check that the throttle shaft fits well, not too loose, or too tight. It should have a smooth, and free movement, but not so loose as to let air past the shaft. Good luck.
Post a Followup
: Re: Re: M won't stay one constant RPM at idle
