Farmall Tractors Discussion Board
Re: Re: MD Vibration
Posted by Jim on May 29, 1999 at 07:06:58 from (199.240.128.77):
In Reply to: Re: MD Vibration posted by rich on May 29, 1999 at 05:40:52:
Why,if the tractor has good power and only uses 2 qts. oil per day, why overhaul it.When you get done you could have more oil use.
Post a Followup
: Re: Re: Re: MD Vibration
