Farmall Tractors Discussion Board
Re: Sleeves{forgot 1 question}
Posted by RED Blooded on May 29, 1999 at 18:43:17 from (206.74.34.118):
In Reply to: Sleeves{forgot 1 question} posted by BDM on May 29, 1999 at 18:12:38:
Those sleeves will fit your block the way it is.It may be cheaper for you to take the block to someone who works on them and them put the sleeves in for you.You wont get as big of a headache either!
Post a Followup
: Re: Re: Sleeves{forgot 1 question}
