Farmall Tractors Discussion Board
1941 Farmall H - further info ref ignition (points timing)
Posted by Bryan Wild on May 30, 1999 at 03:07:22 from (203.97.2.246):
Can anybody please help with info to help me set the timing after stripping the magneto housing to renew points. This model contains coil inside magneto housing. Timing required due to spline output for distributor to rotor arm drive.
This tractor set up seems different to other Farmall H models.
Post a Followup
: Re: 1941 Farmall H - further info ref ignition (points timing)
