Farmall Tractors Discussion Board
Re: front wheels on H
Posted by The Red. Yes on May 30, 1999 at 07:18:53 from (216.192.166.85):
In Reply to: front wheels on H posted by jack on May 30, 1999 at 07:12:08:
Morning Jack. Drive the H up onto a 4x4. That will give you enough clearance to unbolt the rim. Get one tab over the hub and then you have to rotate the assembly to get the other 2 tabs off. Its difficult to explain but it can be done. I suggest you lay down a short 2x4 first then the 4x4. You need that much clearance to get the rim off. Good luck!
Post a Followup
: Re: Re: front wheels on H
