Re: super m carb problems
Posted by Bob M on March 22, 2009 at 08:45:42 from (74.74.132.139):
In Reply to: super m carb problems posted by archie3 on March 22, 2009 at 07:32:53:
Well Brad - if it had been running good and the problem's junk in the carb, remove and disassemble the carb and give the parts a thorough cleaning. Reassemble with a new gasket kit - $25 or so - and you'll be good to go. (Keep in mind the SM carb is very simple and easy to rebuild...)
However BEFORE you get into the carb check your ignition timing! Could be the cam gear hub has broken and messed up the cam/spark timing. It's a common failure on the SM with live hydraulics. And it's consistent with the symptoms you describe. (Correct timing should be within a couple degrees of TDC.)
