Farmall Tractors Discussion Board
Re: Governor adjustment on Super A ???
Posted by Curt Cooke on June 02, 1999 at 05:39:09 from (207.75.224.250):
In Reply to: Governor adjustment on Super A ??? posted by bronco on June 01, 1999 at 20:09:25:
The most common problem in this regard is worn out linkage and related parts. First adjust the throttle linkage between the carb and governor shaft to spec. If the problem persists it's because of worn linkage or the anti-surge spring being adjusted too far in. Back the surge screw out enough to be sure that it's not holding your idle up. The screw is located on the bottom of the governor housing under an acorn nut. If the problem still persists you'll have to compensate for wear by shortening the rod between the carb and the governor, usually by the adjustable turnbuckle on the rod.
Post a Followup
: Re: Re: Governor adjustment on Super A ???
