Farmall Tractors Discussion Board
Re: Re: Re: Re: 3pt Hitch
Posted by Stan(VA). on June 02, 1999 at 06:39:18 from (207.172.109.24):
In Reply to: Re: Re: Re: 3pt Hitch posted by Bob on June 01, 1999 at 21:19:11:
I second that! Keep in mind that this one doesn't require and extra cost bracket to use the original drawbar and includes two 3x8 cylinders. You get down pressure or float capability by just pulling a pin on each side.
Stan(VA).
Post a Followup
: Re: Re: Re: Re: Re: 3pt Hitch
