Re: Fast Hitch Settles Down
Posted by pete 23 on March 22, 2009 at 12:51:35 from (173.87.1.12):
In Reply to: Fast Hitch Settles Down posted by Retcol on March 22, 2009 at 10:40:11:
You need to determine if it is the cyl or the check valve. Unhook the hose to cyl that is not holding hitch up, no oil should come out of cyl, if it does, cyl it is leaking internally. If that checks out ok, move to the check valve block and determine if oil is leaking back through check valve on side that is holding hitch up or just take the plugs out and check balls and springs etc. O-rings on piston in check valve can leak to return side also.
