Re: Fast Hitch Settles Down
Posted by Hugh MacKay on March 22, 2009 at 12:57:26 from (209.226.247.84):
In Reply to: Fast Hitch Settles Down posted by Retcol on March 22, 2009 at 10:40:11:
Retcol: By the time you reach the SC age you may settle overnight as well. It's 55 years old, has every right to settle.
Seriously, two possible problems, either the hitch check valve, that steel block where plumbing from cylinder meets plumbing from control valve, or you have bypassing within the hitch lift cylinder.
Lift cylinder is easy any hydraulic repair shop can rebuild that. The check valve may be a bit of a challange, check with CaseIH, they may still carry the internal parts.
