Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: 3 good tune-up tips for beginners, back to back (#1)
Posted by MAB on June 02, 1999 at 14:12:14 from (199.240.71.9):
In Reply to: Re: Re: Re: Re: 3 good tune-up tips for beginners, back to back (#1) posted by Milan D. Radakovic on May 31, 1999 at 13:15:53:
you must be careful. My super M almost started with the distributor cap off. I had set the points and was testing to see if I had spark at the points. I had inadvertently laid the distributor on top of the coil wire. Guess it jumped over through the wires. Kind of made wonder until I had seen what I had done.
Post a Followup
: Re: Re: Re: Re: Re: Re: 3 good tune-up tips for beginners, back to back (#1)
