Farmall Tractors Discussion Board
Re: IHC 6ft. 3pt disk identification
Posted by JK MN on June 03, 1999 at 08:12:43 from (207.242.199.131):
In Reply to: IHC 6ft. 3pt disk identification posted by Doug Ringer on June 02, 1999 at 06:32:24:
Doug, From you description, it sounds like a mod 122. I had one when I had a vineyard. Had a total of 16 blades. Good heavy disk. Be sure to get the correct blades. Check the spools, or spacers. The ends should be square cut, and the blade will have a "crimp" center, or a flat section in the center of the blade that is approx 4". A regular blade has a curve from the edge to the center, and the spools will have ends with the matching curve.
Post a Followup
: Re: Re: IHC 6ft. 3pt disk identification
