Re: super m cranking problems
Posted by El Toro on March 22, 2009 at 14:38:14 from (205.188.116.73):
In Reply to: super m cranking problems posted by archie3 on March 22, 2009 at 12:52:06:
Are you using a ballast resistor between the ignition switch and the coil? If you are your ballast resistor probably needs replacing. Hal
