Farmall Tractors Discussion Board
Re: Re: WORRIED ABOUT HYDRAULIC PUMP!
Posted by R on June 04, 1999 at 06:10:16 from (207.250.242.167):
In Reply to: Re: WORRIED ABOUT HYDRAULIC PUMP! posted by Don H. on June 03, 1999 at 19:32:57:
DON-
Thanks for the reply. This sounds like it could be the problem. I know what switches you are talking about. The next problem is that the valve doesn't have this switch. The other two valves do, but not the valve for the quick hitch. Instead of a switch it has a bolt through a hole in the center of it. Does anyone know if this is original or if it was a cheap fix of some kind? Could this be my problem? Any information about this would be appreciated.
Post a Followup
: Re: Re: Re: WORRIED ABOUT HYDRAULIC PUMP!
