Farmall Tractors Discussion Board
Re: FARMALL H HIGH GEAR
Posted by The Red on June 04, 1999 at 09:09:47 from (206.246.187.2):
In Reply to: FARMALL H HIGH GEAR posted by Troy Pugh on June 04, 1999 at 08:57:28:
Troy, you will probably have to take the transmission pan off. It sounds like either a worn shifting fork or a worn 5th. gear. If the gear shift is staying in the other gears, I would think the shifter itself is fine. You should get some good responses on this.
Post a Followup
: Re: Re: FARMALL H HIGH GEAR
