Farmall Tractors Discussion Board
Help With Splitting SuperMTAD
Posted by TMAC on June 04, 1999 at 17:54:51 from (207.144.168.239):
I have the clutch housing supported and the engine hanging on a chain support. The front end and side rails are removed. In doing so I had removed four bolts on each side of the engine but it will not pull away from the clutch housing. Is there something I overlooked?
Post a Followup
: Re: Help With Splitting SuperMTAD
