Farmall Tractors Discussion Board
H Strainer Bowl and Charging Rate
Posted by B. Batty on June 05, 1999 at 18:52:39 from (205.188.193.162):
I adjusted the movable brush on generator for minimum charge rate but it still charges at about 16 amps at low switch setting and about 20 amps at high charge setting. The manual says the generator should be adjusted for a max. charge rate of 9 to 11 amps (hot) and 13 to 16 (cold) with switch in high charge position. Should I be concerned? If this is not good, how can I reduce charge rate further?
Also, are replacements available for the filter screen in the gas strainer bowl?
Post a Followup
: Re: H Strainer Bowl and Charging Rate
