Farmall Tractors Discussion Board
Re: Super A -- 12 volt system?
Posted by RKS on June 05, 1999 at 20:22:14 from (171.213.123.178):
In Reply to: Super A -- 12 volt system? posted by bronco on June 04, 1999 at 21:15:53:
Bronco - Larry's right, forgot the resistor. The change would have required the addition of a resistor in series between the coil and ignition, to prevent the 12v battery from toasting the coil. It is ceramic, about 2-3 inches long, and has a "fuse looking" coil that mounts between two contacts. In fact, it really is a fuse. Maybe that's it now. RKS
Post a Followup
: Re: Re: Super A -- 12 volt system?
