Farmall Tractors Discussion Board
Re: Re: Re: Super A -- 12 volt system?
Posted by BDM on June 05, 1999 at 21:50:46 from (24.4.252.128):
In Reply to: Re: Re: Super A -- 12 volt system? posted by Larry on June 05, 1999 at 14:19:35:
Usually, but then again there are coils availible that run on 12-14 volts, and depending on the resistor, they usually have them running around 8-9 volts. You can run a stock coil that used a resistor at 12 volts, but it sure doesn't help with the longevity. Most performance coils that are hitting 60k-80k volts run at 12v to achieve that, most of the old stock coils{like in Chryslers} ran around the 20k-30 mark. I know most of the factory ratings are at 30k-40 but if you have ever read real world test, you would be surprised. The GM HEI is a good example of a 12v system.
Brian
Post a Followup
: Re: Re: Re: Re: Super A -- 12 volt system?
