Re: One third choke and popping
Posted by Janicholson on March 22, 2009 at 17:10:37 from (64.83.193.190):
In Reply to: One third choke and popping posted by Randy D McClenahan on March 22, 2009 at 14:49:12:
A internally cracked manifold can do it. as can a plugged main jet. Popping noises can come from stuck open intake valve/s or mis adjusted valves. Do a compression check first, then set the valves, do the carb clean, then look to the manifold. JimN
