Farmall Tractors Discussion Board
Re: 2-14 plow
Posted by BOB on June 06, 1999 at 18:04:36 from (209.214.48.14):
In Reply to: 2-14 plow posted by Andy Glines on June 05, 1999 at 23:04:49:
I ASSUME WHEN YOU SAY TRIP, THAT YOU MEAN YOU TRIP THE MECHANICAL LIFT TO RAISE THE PLOW FROM THE GROUND.(RATHER THAN ATRIP BEAM PLOW) THIS BEING TRUE I WOULD THINK IS MOST LIKLY A LITTLE GENIUS #8. THESE WERE BUILT FROM 1928 TO 1960. THIS PLOW HAD TWO LEVERS TO ADJUST THE PLOWING DEPTH AND LEVEL THE PLOW. IF IT USES CRANKS TO ADJUST THE DEPTH OR DOES NOT HAVE REAR FURROW WHEEL THEN IT COULD BE A LITTLE GENIUS # 12 OR LITTLE WONDER #1. GOOD TURNING
Post a Followup
: Re: Re: 2-14 plow
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
