Re: Ih carburator rebuild problem
Posted by wayne in mn on March 22, 2009 at 17:35:55 from (68.119.25.192):
In Reply to: Ih carburator rebuild problem posted by Teebone on March 22, 2009 at 13:28:21:
When you get the new idle tube you can determine the size & depth.
Drill out most of the brass tube, locate a proper size thread tap (may need to see your nearest gunsmith friend) and carefully run the tap in & out removing chips as you go.
