Farmall Tractors Discussion Board
Re: Thermostat??
Posted by The Red on June 08, 1999 at 06:56:14 from (206.246.187.2):
In Reply to: Thermostat?? posted by Dale on June 08, 1999 at 06:05:02:
Dale, 160 degrees. the NAPA part number is 28 THM.
Post a Followup
: Re: Re: Thermostat??
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
