Re: new rebuild startup
Posted by kopeck on March 22, 2009 at 18:06:25 from (66.243.217.26):
In Reply to: new rebuild startup posted by jonathan mirgon on March 22, 2009 at 17:08:56:
I don't think that's all that bad. These engines really never had a ton or pressure.
If you want higher pressure you could go with a straight 30w or 40w if it's warm out (40w in the cold can be a bit much).
K
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
