Farmall A fan bearing and oil reservoir
Posted by dmiller on March 22, 2009 at 18:19:58 from (205.162.153.3):
Used the A to disc the garden today. As I was finished the fan started to squeel and I realized I had forgotten to fill the oil reservoir at the fan shaft. Got it shut down, filled and doesn't appear to be any lasting damage.
I was wondering if there's a good way to keep from doing this again. Can the reservoir just be filled with grease (with hopes it will not seep out like the oil does)??
Is there a better idea than grease? Obviously the best answer is simply keep it full and don't forget to check it.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
