Posted by Hoss in Me on March 22, 2009 at 18:31:51 from (69.131.127.221):
In Reply to: Super MD (Pics) posted by Andrew Z on March 22, 2009 at 08:37:48:
Id play with the pump timing a little.Easy to check.Take cover off timing gear housing in front of pump.Easy to adjust,loosen bolts on front of gear and turn accordingly.Cant remember which way.Outta have a manuel to use.Pumps are quite simple,dont be asceerd of taking apart and cleaning it up. Hoss
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
