Farmall Tractors Discussion Board
Re: Farmall A - Belly pump replacement
Posted by Daniel on June 13, 1999 at 18:23:43 from (205.188.197.161):
In Reply to: Farmall A - Belly pump replacement posted by Hap on June 13, 1999 at 13:39:55:
You will be way ahead to buy a Super A. There is no provision on the A for hydraulics--no opening in the block for the pump, no pad on the clutch housing to mount the touch control unit, and no good place to mount the levers. Plus, the parts will cost quite abit. I pricd a used, not rebuilt, touch control cylinder unit at $350.00 before rebuilding mine. If you need orignal type hydraulics, buy a Super A.
Post a Followup
: Re: Re: Farmall A - Belly pump replacement
