Farmall Tractors Discussion Board
Farmall Cub: Fan Belt Pulley Removal
Posted by Frank Vantacich on June 14, 1999 at 06:43:26 from (209.63.224.184):
Any one have any suggestions on removing the fan belt pulley from the crank shaft. According to the book it's just pressed on and all you do is pull it off with a puller. I've tried with no success although I haven't tried to hard cause I didn't want to damage anything and there's probably someone out their that has done this and has a simple suggestion. Can I heat it up? I do have to make a plate for the puller jaws to rest on so they don't contact and pull directly on the V part of the pulley.
Post a Followup
: Re: Farmall Cub: Fan Belt Pulley Removal
