Farmall Tractors Discussion Board
Re: Plow mounting for Super A
Posted by bob on June 14, 1999 at 08:15:56 from (209.215.52.36):
In Reply to: Plow mounting for Super A posted by Jerry Norton on June 14, 1999 at 05:52:16:
the drawbar turns around and mounts in the froward set of holes on the rear axle housings. remove the bolts from the side plates to allow the drawbar to hinge. you should have a curved rod that will attach to the drawbar and the right rockerarm of the touch control. the front of the plow beam should have two large coil springs and a plate. the plate bolts to the drawbar with two large carriage bolts. it will bolt to the right side of the drawbar. the beam is lifted by a chain from the rear rockshaft. page 39 of guy fays "farmall letter series tractors" has a good picture. good luck
Post a Followup
: Re: Re: Plow mounting for Super A
