Re: H ignition issue
Posted by Bob M on March 23, 2009 at 05:42:59 from (151.190.254.108):
In Reply to: H ignition issue posted by Ty Wilkins on March 23, 2009 at 04:48:40:
If there is a grounding wire (wire running from the mag to the ignition switch) disconnect it. If the mag is good it will now make a spark.
Otherwise I'd bring the mag back to the rebuilder.
To your question: Yes, even if the mag is out of time with the engine it will still make a spark.
