Farmall Tractors Discussion Board
Help with International 504 Diesel
Posted by Gina on June 16, 1999 at 07:26:42 from (128.192.177.5):
Help me out guys....we have an IH504 diesel. We had to replace a part. I don't know the name of the part but here is what I do know: it enables the tachometer to work and is part of the oil system on the tractor. We found the part at a tractor graveyard and put it back on. This part is located just off the oil pump. It merely pushes on. The problem is that is wouldn't fit tight. My husband was told to try applying JB Weld. He did this and let it sit up as directed. When he went to move the tractor, the part was slightly loose. The tractor isn't blowing oil and the tachometer is working fine. The oil pressure is okay also. Is it okay to run the tractor or do we need to try to make the part secure ? My father-in-law thinks that the original part also had some play in it. I know this is sketchy information. Thanks for any help!
Post a Followup
: Re: Help with International 504 Diesel
