Farmall Tractors Discussion Board
Re: Re: B Brake / Clutch Pedal Assy.
Posted by Curt Cooke on June 17, 1999 at 05:50:57 from (207.75.224.250):
In Reply to: Re: B Brake / Clutch Pedal Assy. posted by Phil Auten on June 17, 1999 at 05:15:39:
These things are not easy. I have done several. Heat the hub of that pedal with a torch, get it way hot and then either tap the shaft out of it or tap the pedal off the shaft. You're right, there are no more retainers. Be careful when you're tapping not to break the cast guide at the base of the bell housing where the shaft goes over there to grab the brake band. Be aware that the problem you're having is friction with the clutch pedal on the brake shaft so the shaft has to be removed. cleaned and lubricated. It's not hard, just a nuisance.
Post a Followup
: Re: Re: Re: B Brake / Clutch Pedal Assy.
