Farmall Tractors Discussion Board
leaking hydraulic pump
Posted by mark on June 18, 1999 at 10:41:35 from (132.8.121.2):
I have a 1959 Farmall 140 that the hydo pump has started leaking on. It sprays fluid out near the lower right mouting bolts (there are 4, 2 on each side). What do I do? Can this be repaired or do I need a new one? Is this just a leaking "o" ring? Where do I start and in what sequence do I remove the pump? i.e. hydro lines first , then pump etc. thanks for the help and where can I get a pump.
Post a Followup
: Re: leaking hydraulic pump
