Farmall Tractors Discussion Board
Re: McCormick Farmhall 460
Posted by Harold H on June 20, 1999 at 13:44:19 from (207.244.8.78):
In Reply to: McCormick Farmhall 460 posted by Daver on June 19, 1999 at 23:58:26:
Daver,
The Farmall 460 is the row crop version of the 460 and was the most common version of the 460. It's design evolved from the H to the 300 to the 350 to the 460. The International 460 was a utility or standard version. There was also a industrial version International 460 which had a heavy duty front axle and heavy duty grill and was standard with industrial tires and a few other minor differences from the regular International 460. The International 460 Hi Clear was a row crop version of the International 460 utility tractor which but had the same rear axles as the Farmall with the 38" rear wheels but still retained the short wheelbase of the utility and the lower seating position. The Farmall 460 (your tractor) (62 serial numbers were 28029 - 31551) was row crop and could have a tricycle front, single front, or wide front axle. The seating position is high on top of a flat transmission top floor. The Farmall 460 Hi-Clear was a high clearance version of the Farmall 460 and had drop type rear axle housings for use in sugar cane or other simular tall crops. There was also a International 460 Grove which was shielded to use in orchards and had the low profile of the International 460. All 460's were equipped with either a 221 cu in 3 9/16 x 3 11/16 six cylinder gasoline engine, or a 221 cu in 3 9/16 x 3 11/16 six cylinder LPG engine, or a 236 cu in 3 11/16 x 3 11/16 six cylinder diesel engine. The shipping weights of the 460 diesel in various versions were; International 460 diesel 4832 lbs, International 460 Hi Clear Diesel 5198 lbs, International 460 Grove Diesel 5516 lbs, Farmall 460 Diesel 5483 lbs, and Farmall 460 Hi Clear Diesel 5978 lbs. These weights are without any ballast or weights. The Nebraska test for your Farmall 460 diesel was test # 672 with 46.21 db hp, and 50.10 belt hp, corrected to sea level 47.99 db hp and 52.19 belt hp. Hope this information helps.
Harold H
Post a Followup
: Re: Re: McCormick Farmhall 460
