Posted by El Toro on March 23, 2009 at 11:18:43 from (64.12.116.73):
In Reply to: Sleeves and Rings posted by Bud W on March 23, 2009 at 10:35:46:
If you're going to tear the engine down I would install a new sleeve kit, bearings and have the head redone. You should have the crankshaft measure for wear at your local auto machine shop to see if it needs to be ground undersize. Get your new bearings from them. You need to clean that area of the block where the sleeve seals are installed of any rust or dirt. If the block is sludged you probably should have it dipped and all the oil passages cleaned. Good time to check the clutch disc too for wear and have it recovered. You don't want to have a problem later and need to pull it apart again. Hal
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
