Farmall Tractors Discussion Board
loosing fluid from right rear tire and ...
Posted by George on June 21, 1999 at 06:57:22 from (198.81.197.3):
#1 - The bolt for the right rear tire keeps coming loose and leaks fluid. The lugs are all tight and there's no fluid on the backside of the tire, just from the loose bolt? Some have suggested lock-tite but I'm afraid to use it. Any ideas?
#2 - Where can I get a seat, like the one it came with originally? TSC and like stores have seats, but they all seem to be foam filled and not spring?
#3 - What I believe to be the serial plate on the right side of the engine block (the same side as the hydralic pump) is S11681 which I think would be a 57? Anyone know for sure?
#4 - How do I decipher all those codes stamped (raised letter) in the housing on the right side just below the seat ... I lost my Captain Crunch Secret Decoder Ring!
Thanks ......
Post a Followup
: Re: loosing fluid from right rear tire and ...
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
