Farmall Tractors Discussion Board
H electrical short
Posted by Dean on June 21, 1999 at 14:20:06 from (162.57.91.58):
After pressure-washing decades of grease and grime off an H I recently purchased, I tried to start it and could see sparks coming from behind the plate just behind the foot starter button. I figured I probably created a short during the pressure washing, but am not sure. I left it to let everything dry, but now it won't turn at all. I'm pretty novice with tractors and even moreso with wiring. What items should I check?
Post a Followup
: Re: H electrical short
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
