Farmall Tractors Discussion Board
Re: 140Hi-crop AV
Posted by Ludwig on June 21, 1999 at 16:50:34 from (134.241.31.1):
In Reply to: 140Hi-crop AV posted by Dan Quaranto on June 20, 1999 at 18:38:58:
I'm sure someone else will have more specific information, but on all the earlier hi-crop versions the rear-end used a chain driven final drive from the axle to the hub at the rear wheels much like the early F series tractors did. Often because the total gear ratio was reduced because of this the rear tires were actually smaller than the non hi-crop versions of that particular machine.
Other than that I believe that the front-end was setup differently to accomodate the higher ride height.
Post a Followup
: Re: Re: 140Hi-crop AV
