Farmall Tractors Discussion Board
Re: 1066 Oil in the radiator
Posted by SDman on June 21, 1999 at 20:16:08 from (63.65.237.180):
In Reply to: 1066 Oil in the radiator posted by Phil on June 21, 1999 at 19:53:31:
When this happens in a 400 Series IH engine, the first thing to suspect is the engine oil cooler which is the 2 foot long tube at the lower front right-hand corner of the engine. The bundle inside it can rupture, sending engine oil into the cooling system. The best product to clean out the cooling system I have found is a product called RESTORE, which is available from your local Cummins engine dealer. Do this & replace the oil cooler & you should be OK.
Post a Followup
: Re: Re: 1066 Oil in the radiator
