Re: M charging rate
Posted by Chuck's Repair on March 23, 2009 at 12:26:42 from (162.40.106.165):
In Reply to: M charging rate posted by The Dukester on March 23, 2009 at 12:12:11:
The third brush is adjustable. Moving it closer to the insulated brush will increase output. There should be a screw on the back plate that you need to loosen so that the brush can be moved. All this is assuming that the charging system is in good shape. Chuck
