Re: Marvel Schebler vs. Zenith
Posted by redblood on March 09, 2009 at 13:17:29 from (205.188.116.19):
In Reply to: Marvel Schebler vs. Zenith posted by Brad in Tx on March 09, 2009 at 11:44:28:
The Zenith is very simple only 2 adjustments.
Idle speed and idle air/fuel mixture. Main is preset.
Marvel has 3 adjustments. Idle speed, idle air/fuel and main jet.
With an overbore main jet adjustment may be benificial for tuning.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
