Re: M charging rate
Posted by Tom 43 on March 23, 2009 at 12:30:07 from (70.142.52.59):
In Reply to: M charging rate posted by The Dukester on March 23, 2009 at 12:12:11:
If you have a voltage regulator, the high and low on the light switch are inoperative. Perhaps you can adjust the third brush on the generator and/or increase the spring tension on the voltage regulator to get about 7.3 volts at the battery.
