Farmall Tractors Discussion Board
Re: Int 706 1963-1967
Posted by Harold H on June 23, 1999 at 18:46:43 from (207.244.9.109):
In Reply to: Int 706 1963-1967 posted by Richard Henninger on June 23, 1999 at 04:55:24:
Richard,
Is your 706 a Farmall or a International. The serial number is the easiest and most accurate way to determine the year model. If the Serial number plate is missing, you can use casting date letter to get close. To convert the two point hitch to three point hitch, you can either use an adaptor, or if you want to completely convert it, go to a salvage yard and get all of the three point hitch parts from a salvaged 706 or 806. The same goes for the seat parts. Get the mounting and framework from a salvage yard. The cushions are available new from several sources on the internet.
Harold H
Post a Followup
: Re: Re: Int 706 1963-1967
