Farmall Tractors Discussion Board
Re: oil pan
Posted by Lary on June 23, 1999 at 20:19:18 from (206.228.213.201):
In Reply to: oil pan posted by larry on June 21, 1999 at 06:06:24:
Take your pieces to someone with a wire welder and have them to weld your pan back together. Go to a plumbing supply house and get a cast union and cut it in half.. Get a hole saw the size of the outer diameter of the modified union. Use the hole saw to cut out the old damaged plug hole. ( Leave the old plug in place and drill your pilot hole through it ) Have the welder to weld the modified union in the new hole. Install a pipe plug in the modified union, use teflon tape as a thread sealant, and now you have a new plug and threaded hole. Cost should be minimal
Post a Followup
: Re: Re: oil pan
