Farmall Tractors Discussion Board
Re: 706 Diesel
Posted by Wayne on June 24, 1999 at 19:25:19 from (209.240.200.114):
In Reply to: 706 Diesel posted by T16 on June 24, 1999 at 18:59:37:
If it is plugged with what looks like coffee grounds the pump needs repair. Take the small cover off the side of the pump [2 screws] and see if it also has this problem. A plastic disk inside the pump is starting to go bad. Do not use alcohol deicers in the fuel system on these pumps.
Post a Followup
: Re: Re: 706 Diesel
