Re: What's better for plowing Wide/Narrow?
Posted by Ferd on March 23, 2009 at 16:25:04 from (71.111.50.84):
In Reply to: Re: What's better for plowing Wide/Narrow? posted by Hugh MacKay on March 23, 2009 at 12:02:16:
That's the primary reason John Deere came out with the roll-o-matic for narrow front tractors. Keeps even weight on both front wheels and saves knuckles. I'd sure rather plow with a wide front.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
